Adjustable up & down
13 Jan 2016
any idea where I can get an adjustable up & down lighter for outside?
I need the bottom half to shine straight down but the top light to shine at an angle
Cheers
Maybe better two separate lights.
Although it seems strange having uplighters outside, that would just cause light pollution and add your electric bill?
Is there nothing at all on the market as simple as this?!
John, I can't imagine 2 Led outdoor lights are going to cause major issues.
The reason I need it to adjust is because my house has a gable, the current up/down lights are useless because the up light just shines into thin air & disappears
I'd like it to shine up the brickwork/gable which would also shine on the house number (higher up in the brickwork)
I quess he means the beam angle, like putting in a wide beam lamp
images
Oh I see what you mean, you mean it won't shine right up the brickwork. Good point! Hmm not quite sure what I'm after then.
I know you can get those lights that go in the ground & shine up but that's not really an option,
So what is it that Rocky's example does that you don't want, or vice-versa?
images
The top half shines directly up, I need it to shine at an angle.
I've got 2 lights to be replaced. So imagine 2 lights shining up the side of a triangle.
Bottom half is fine. Hope that makes sense! Thanks
Your house number is on a gable end? o_O
Click here.
It is yes, it's not a conventional house, I'm sure you've gathered that!! The rear gable is all glass, the front is the front door, glass & the house name in the top of the gable actually built
