- Joined
- 7 Oct 2012
- Messages
- 41
- Reaction score
- 1
- Country
If you were to install lights for an average sized (home) garage today in the UK, would you consider LEDs yet? I mention the UK because a lot of thoughts on this subject or online forum posts/videos are based in the US where LED lighting may be cheaper and more widely available. I also find that a lot of information is from too long ago to make an informed decision, when LEDs were considered to not be developed enough yet.
Do you feel that the time has come whereby LEDs have reached a good enough level?
From my brief research online (although I don't know many competitively priced places to buy such lights) I have concluded that T5 Fluorescents right now are still a good choice. The actual tubes are a few pounds each even for the long 5/6ft ones, and the Lumen output seems to be much higher than LED. They seem still very efficient.
A twin 58W T5 high frequency 5ft fitment including tubes comes in at around £30 on tlc. The lumen output can be around 5000 lumens per tube I think. So approx 1000 total.
The equivalent twin LED 5ft fitment comes with everything inside it required and is almost exactly double the price. It uses half the watts (50W for both tubes combined) and gives out about half the lumens total output. I'm also unsure if the LED tubes are replaceble in a lot of them.
I have noted that there are some options to purchase replacement LED tubes that have the standard battern fitment of T8 (not sure about T5) which plug straight in to your old/existing fittings. You just need to uninstall the ballast of old, and fit a new LED starter in some cases or just wire direct. I wonder if it would be cheaper to re-purpose older fittings or even buy some, with the intention of using these types of tubes. They have the benefit of also being replaceable in the future.
All things considered, unless I am missing something, I can't see an argument for LED at all? Twice as much cost and twice as many required to get the same output...? Is that right? Might not be replaceable.
The benefits of LED instant start are moot if one uses T5 high frequency ballasts as well.
It feels almost wrong to be buying from scratch something that isn't LED these days, but is it simply the case that Fluorescents are still the better choice? Maybe I am looking at some bad LEDs. Would appreciate if someone could link to good ones. I know there are other things to consider like beam angle and efficiency.
I realize that with business decisions it may be different if you needed the lights on A LOT as LEDs would provide cost savings. In this day and age, who wouldn't want to run low cost lights. But for a home garage even with regular use, are LEDs worth it yet? From the ones I can find online it does not seem so.
