Will a cavity sock stop vermin / mice ?
24 Jul 2015
Planning to use a cavity sock to stop the gap between the 2 leaves at wall plate height
Will this stop mice from getting into walls ? lots of the little blighters in this neck of the woods
Cheers
Closing the cavity is so 1950's. Nowadays, wall insulation should run continuous with the roof insulation.
This a conversion and walls are not insulated in the cavity. We are doing interior celotex
is there no fire regs thingy that is should be fire stopped ?
i wonder have you lived with mice dancing on your plasterboard ?
