- Joined
- 11 Nov 2017
- Messages
- 16
- Reaction score
- 0
- Country
Hello all.
Wondering if anyone can help me with some insulation advice.
I have a 1890s Victorian terrace that had an existing DIY loft conversion done to it in the 90s.
Structurally its sound but the insulation is 55mm expanded polystyrene and is between the 75mm rafters and flush against the sarking felt therefore leaving no room for ventilation. I've now pulled down this insulation and plaster board.
Between the 75 mm (420mm centered) joists was filthy flattened mineral wool that I've now cleaned out as well.
So I have a blank insulation slate and going through the options to achieve as close to 0.16 W/m²K as possible. At floor level I will use 270mm mineral wool however my rafter level is a problem because of the lack of head room.
I think I only really have about 100mm below the rafters to play with. Because of the skinny rafters (75mm) and limited headroom I'm thinking of using a foil quilt product like superfoil SF40 (40mm) 25mm battens and 35 mm PIR board (which manufacturers tell me will achieve 0.18).
I'm aware of all the doubts and issues surrounding foil insulation.
As good as the manufacturers claims sound I'm aware there is a good chance it won't achieve this U value but I'm interested to know if anyone has actually used it to good effect?
If foil should be avoided can anyone advise on a different method of rafter insulation for my scenario?
many thanks in advance.
