Indeed - that's what I recently intended to type (now correctedWould that not leave you with one Red and a Black marked Brown
Yes.Would that not leave you with one Red and a Black marked Brown
Yes, but presumably with the L still red. That's what seems odd (mixed conventions in the same cable) and what I thought might well not be allowed.... So a red/black was ok for L&N but brown sleeve on black for SL.
But in places which had not been altered the red sleeve remained and a silly situation arose (and we refused point blank to change it) where in a 2g switch, we converted one to 2 way so the new harmonised cable and the existing black were sleeved brown but the remaining (unaltered) switch was identical but black sleeved with red.Yes.
Sorry I was typing when yours came in.
Yes it felt totally wrong and counter-intuitive. The regs were trawled by others further up the chain (not me) and apparently is reads 'sleeve with brown'Yes, but presumably with the L still red. That's what seems odd (mixed conventions in the same cable) and what I thought might well not be allowed.
And for exactly that reason I don't understand that people mark black and grey cores with brown sleeve.I thought Red was still a recognised colour for live, so although odd, Red and Brown is ok, though as said id mark both Brown.
Like in Pre wired emergency Rock roses with Harmonised flex, they use Brown and Black cores as two lives and a Blue Neutral, no attempt is made to mark the Black as Brown as Black is a recognised Live colour nowadays.
I suppose that depends upon what you mean by "recognised". It is still accepted as identifying Line (or Line 1 in 3-phase) in 'old colours' (or mixed-colours) installations, but it is not recognised as identifying anything in terms of Harmonised Colours .I thought Red was still a recognised colour for live, so although odd, Red and Brown is ok, though as said id mark both Brown.
Well, black means L2 (in harmonised colours) and grey means L3, so if they are actually carrying 'L1' current, I suppose it's appropriate to identify it accordingly (i.e. brown).And for exactly that reason I don't understand that people mark black and grey cores with brown sleeve.
So tongue in cheek question, should we sleeve black for a 2way circuit on L2 in a 3ph system?Well, black means L2 (in harmonised colours) and grey means L3, so if they are actually carrying 'L1' current, I suppose it's appropriate to identify it accordingly (i.e. brown).
It's not really an issue in a single-phase installation, but I suppose it could be in a 'mixed' (3-phase and 1-phase) scenario.
Interesting questionSo tongue in cheek question, should we sleeve black for a 2way circuit on L2 in a 3ph system?
That's certainly how I would do it. Like you, I would never mix new and old colours on the same cable.The sleeving question came up on another electrical forum the majority sleeve as below: ...
That seems to be how things are now done. However, if (I imagine very unusually) a cable carries line conductors for single phase circuits on two different phases, it would seem sensible (and 'safer') to identify them with the appropriate (brown, black or grey) phase colours.For a single phase circuit connected to a 3 phase supply, the line conductors should be brown. It used to be common for single phase line conductors to be the phase colour when wiring in conduit and trunking but apparently no version of the regulations permits this. It does look cool though...
