Anything round the back will be spare, you wouldn't be able to nail it anyway.
do you need to bolt the joists to the rafters for lateral restraint?
And since they are pairs that would mean bolting them together and making them overlap on the central wall.
I realise that, but what are the limits?
If you're working from the central wall, then you can cut and notch the joists, and then slip them into place. As Ian has said, the excess strap can't be nailed behind the wall plate, so just push it back, and ignore it. Look at the joist hanger, find the lowest hole, and you'll realise that that is the highest point you can set it; as long as that. Obviously, with 7" joists, you'll need to put in noggins for lateral stability, and it'll be good to nail them together where they meet on the central wall. You may find it best not to start nailing the hangers in till you've made sure that everything is working out level, and you may need to pack any gaps under the hangers with slate to keep things tight.
Where is the SE recommending steel though; we haven't seen any plans, but I can't see why a steel is needed.
Notch and champher in conjunction with the joist hangers is belt and braces, but it would be the BCO that accepts or d You'll nail into the joist from the sides of th hangers, and if you want to bolt the overlapping joists, then no problem. As to putting the new joists alongside the old ones, and then fixing them together, as the old ceilings coming down, you might as well take the old ceiling joist out as you go. And if you were to manage to keep the old ceiling in place, then fixing the new ones to the old ones, might cause the ceiling to flex and crack, so I'd make sure they were seperate, and a gap between the old ceiling.
On the posh ones it will say if your face fixing it use 20 nails of if your strapping it use 14. I'd just knock a twist nail in every hole you can see.
He will be charging you the same money wether he designs it with steel or timber.
A steel might sit under your purlins and have a shorter span to the central wall.
It's only a 3.4m span form the centre wall to the wall plate, so what's he bitching about. Now with the 4.4m span in steel, then you've got to bed it into the wall, engineered bricks to support it, party wall agreements unless you're a detached property; what is the guy up to. As the C16 wooden joist tables will show 3.5m at 400 centres, I can't see an issue, so run it past the BCO, and see what he'll accept. And appologies for suggesting the removal of the existing joists, yes, they'll be nailed into the rafters. But rather than just lay them alongside, look at the layout, and even put them the other side of the rafters. But no great shakes either way - common sense required here.
If you're going to suspend the joists, then nail through every hole, if you're notching them, then not so many nails needed, as they are just providing a degree of stability.
