Really?Any fault code on the screen? If you're having to reset it suggests it's not detecting the flame or the pump isn't pumping properly and it's overheating.
No, if you read on to the post after mine you'll see what the op said about fault codes not appearingReally?![]()
Easy job get Vaillant out and replace faulty mass flow sensor as this is keeping it in comfort mode, common on these easy job
