Im in Surrey. Tolworth rise South KT5Where in the uk are you?
It may at some point been split phase or three phase but you have not got it any more and it would likely cost a lot to have it installed. There are exceptions but in the main domestic properties have a single phase supply of either 60, 80 or 100 amp, consumer units have to be less than 125 amp and in most cases are 100 amp above that requires a distribution unit which should not be under the control of an ordinary person.
In the main although you may have three phase motors, my fridge/freezer and freezer have three phase motors as does my washing machine, they are supplied with single phase and it is converted to three phase inside the appliance with an inverter.
USA had DC supplies right to end of 20 century, I have not seen one in the UK, I have seen 110 volt supplies from private generator in the village, Llwyngwril and I am told Manchester had a hydraulic main but these are all long gone now.
Cheers for that, i think ive sent you a pm lolPM me, I may be able to look on some maps
I also bought a 30hp rotary converter
Cheers for the headsup. The RC is waaay bigger than id ever need so I could get a smaller one if required, just that it came unused at the right money, so with big is good biggers better in mind I grabbed it. The biggest motor will be on the lathe, around 5kW. Am good with my neighbors so if theres a problem I can find another way.which is 23 kW running at full load. Much higher currents when the motor is starting from stationary. That size of load requires that you notify the DNO and accept that they may ban the use of equipment with that loading on a domestic supply. If you do not notify the DNO they are likely to discover the load when they investigate complaints from neighbours about voltage fluctuations.
Now that is encouragingWe have three phase to the head, but only a single phase meter. Whew en the guys came to replace the metal head with a new plastic one they said it's actually in reasonable nick for is age, they said some times they find the spare phases just heat shrinked and tucked behind. Maybe yours are all there somewhere.
However in our case the lights dim even switching on the vacuum cleaner, a normal sub 1kw machine so I wouldn't try even a relatively small 3 phase motor.
It looks like if we got 3 phase it would cost a bit more in line rental, and there may be a cost for additional meter.
Ah, but is it a false indication?I get indication of power when touched with a neon.
Whatever you do, do not open that.Im wondering if there might be anything thats capped off under the triangular cast iron cover
No, that's the neutral.or in the neutral connection?
There isn't.Ive only basic experience with wiring, just hoping theres 3 phases in there somewhere lol.
I shouldn't think so.Wow, I never heard of a dc connection before! im guessing thats the square white box on the left.
There is only one way.Am good with my neighbors so if theres a problem I can find another way.
