- Joined
- 27 Jan 2008
- Messages
- 29,645
- Reaction score
- 3,667
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
You can get static inverters which are not fixed to one motor, however where there is an inverter per motor it also does the soft starting so you don't get lights dimming when you switch on, because of quantity made getting an inverter to work all the motors is often more expensive than one to power each motor, but step one is check how the motor is wired.
With small motors often they are 230 delta and 400 star but larger motors at 400 delta and 690 star so by starting in 690 volt setting it does not put on so much load then once running you swap it to 400 volt settings it is called star/delta starting. If the motor is 230 volt delta then the inverter does not need to step up the voltage, so they are cheaper than those which need to step up the voltage.
I think you will find three phase is expensive, OK inverters are not cheap but it is a one off cost.
