Got a minor issue. After ideas. My lighting circuit for the kitchen downlighters was put in as per my design. Nice loops left that would poke through the holes once the ceiling was boarded and plastered. So plastering finished, 58mm holes cut and good as gold 22 out of the 23 loops of wire are in exactly the right place. In fact all are as per my design. But, my design was flawed. Only when I was cutting the holes did I realise this and corrected to make even spacing. Problem now is that one of my loops is on the other side of a joist. I can see the wire going through the joist to the loop, about 30mm from my new correctly placed hole but I can’t pull it back through the hole as the cable is clipped by each loop.
To me the idea is simple. Cut the wire and join in a new loop for this downlight. But access (58mm hole) and very little play in the wire to be joined into is the issue. Kind of like keyhole surgery. No access above and I have a boarder of joists around preventing threading new wire. Thoughts?
