Evening all,
I got home today to discover a tamper fault on my Texecom.
I tried doing the latching walk test and it came up with a '......B......' on the LCD display. Not really sure what this means from the manual but anyway I progressed and opened up the panel. Below is the inside of the alarm panel. It was installed by the spark doing the rewire, a little over 4 years ago.
The instruction manual says that by bridging the tamper link I can diagnose whether it is a bell tamper (LED remians on) or a global system tamper (LED extinguishes). I removed the yellow and blue wire in the TAMP terminals (presumably these loop between all the PIRs and magnetic contacts?) and bridged as below.
The tamper LED remained on, so according to the instruction manual I have a bell tamper.
My questions are:
1) Have I completed this test correctly? The unit was still in engineer mode with the cover off - would this not cause a tamper in itself (basically, should I have put the lid back on and exited engineer mode)
2) If I have identified this tamper fault correctly, how do I go about rectifying it and is there an easy fix (or bodge) where I could use the alarm without the tamper circuit in use on the bell box. While not ideal the alarm is for domestic use and I doubt anyone that bothered about coming in would go to the lengths of finding a very long ladder to climb to the top of my house to tamper with it...
Thanks for any advice
My questions are:
