turning a window to a door...
20 Dec 2013
London
Hi all
I need some advice....If I want to turn the window to the side of my garden into a door
is it do-able?
there is only a lintel at the bottom....i can t see one at the top unless the blue circled section is counted as a lintel? its just vertical bricks....
the other concern is there is something called a tie rod iron plate thing behind the pipe (see green arrow) - this is because there was some bulging apparently long time ago
and i dont want to weaken anything of course!
i should add the reason i want to add a door to the side is i want to possible turn this into a side extension - so its something of a utility room that i can just access from inside the house (kitchen) via the current window......
and obviously add a window or bricks where the plant pot/bench is to close it off.
and cover the circular drain somehow too. maybe just lay some vynal on it to keep access. i dont want anything too fancy. just a space to do laundry etc. but access via the kitchen obviously and not garden
The bottom i snot relevant, its a cill not a lintel.
The top is a soldier course brick arch, it may be ok to knock out the window and install a door retaining the arch -it depends on how stable the brickwork is and whether the inside has a proper lintel.
I cant see the tie rod.
If the wall stays up now above a window, it will stay up above a door. Tie rod or not.
You have an arch circled in blue. These are self supporting.
so i would basically keep the arch - and lose the lintel below the current window and a door can literally slot in?
lol - you know what i mean! i am used to lintels!
there is not lintel....this is my point....i am worried about putting a door for this reason......
the tie rod you cant see it - but it's basically where the green arrow behind the pipe
Here is an angle where you can see these tie rod things.....if that's what they are called!
Tie rod or bar with a Pattress plate on the end.
thanks! whatever it is - it makes me anxious about touching anything on this wall.....
but it seems a door to replace the window shouldnt be a problem by the sounds of it!
Is that a boiler flue by arched bricks ? if so may be to near(planned door) for regs ?
and yes this is a boiler flue....if anything however the max height of the door will actually be lower than a max height of a window .....
but obviously wouldnt do anything without permission anyway.
i just wanted to get a few ideas on if it was even possible :)
