We recently had a floorer in to relay some Karndeen looselay flooring in the kitchen - he took two strips up and we were all horrified at what was underneath ...
I should point out that the kitchen was completely gutted and new floor boarding put down in October 2015, so that damage from dampness has happened in less than 3 years.
With an expensive kitchen less than 3 years old I haven't leapt in with a hammer and saw, taking lumps of plasterboard out, however, I clearly need to get to the bottom of this, so today I removed the skirting board to try and get a look at the mains water pipe I know to be behind the wall in that area.
**side note** About 6 months before the kitchen went in we had a new stopcock fitted just inside the door you can see on the left hand side of the photo, with a new mains pipe feeding from the stopcock up into the airing cupboard and loft above. Prior to the refit, that side of the kitchen you can see in the pic was an outside wall with no cavity. As part of the building work, they battened the wall, installed celotex panels between the battens and then plasterboarded over the top, so the mains pipe is not channelled into the plaster or brickwork but sits in the void between the outside wall and false internal wall.
With the skirting removed, I cut some of the plasterboard away to get a look at the mains pipe and on inspection, it's completely dry, there's nothing running down the outside of the pipe - furthermore, there's no obvious signs of dampness on the brickwork of the external wall I can see...
So I'm obviously thinking what could've caused this and I keep coming back to the first winter after having the new stopcock under the stairs - I was amazed at the amount of condensation collecting on the T piece of the stopcock, to the extent that it was dripping off onto the flooring underneath and making a wet patch. I ended up putting a small margarine tub underneath to catch the drips.
Given that the section of exposed pipe in the photo is about two feet from the stopcock and the water would still be very cold in this section of the pipe in winter, do you think it possible that condensation on the mains pipe could've caused this amount of dampness ?
The damp area is about 60cm wide and extends about 30cm into the room.
