ok, had a couple of things done recently on recommendation of a plumber as we wanted an unvented cylinder :-
Very old street level stop tap replaced by local water board (no charge)
Plumber then came round to replace two very old internal stop taps with a single proper full bore one
There is a 15mm feed into house.
Plumber then measured the flow rate at the kitchen tap as 13 litres per minute which he says is fine to run an unvented cylinder. Standing pressure is 3 bar and flow 1 bar.
We want to convert from vented to unvented to run a new large mixer shower and lose the loft tanks.
So can we indeed have an unvented cylinder ? any help would be appreciated thanks.
