- Joined
- 8 Sep 2010
- Messages
- 25
- Reaction score
- 0
- Country
I want to erect some sort of partition at the edge of my garden where it adjoins the public footpath. It is simply laid to lawn and there is nothing in it to nick. It is on a corner of quite a busy part of the estate as far as foot traffic is concerned and some people use it as a shortcut across the corner. To be fair, as it is not delineated it could easily be taken for a piece of council grass and in any case some of the youngsters around here walk about as if they are not conscious.
I was thinking of knocking a few posts into the ground and stringing a chain across them, that should do the trick and if I see them stepping over it I will have an excuse to get my 12 bore out and shoot them..... only joking folks
Travis Perkins do some metposts with a spike which can be driven 600mm into the ground. The post has a 75mm square housing to accommodate for wood posts of that size. Water, gas and electric service pipes and cables are probably under the areas in which I wish to drive the posts hence the title of this post.
1) Is there a chance of hitting them and
2) anyone got any better ideas to achieve what I want to do, nothing fancy (another word for expensive) required?
Thanks for reading this far and thank you in anticipation of some helpful replies
