Wiring the live to the L on the new fan causes it to run continuously. Wiring the live to the T causes the fan to switch on and off with the light and the timer doesn't work.
Any ideas?
You cannot then. It requires a permanent live to L, a switched live to T and a neutral to N.Trying to get the timer working on an Expelair VX100T. There's a single live, a neutral, and earth cable from the socket the previous fan was wired to.
Are you sure?Wiring the live to the L on the new fan causes it to run continuously.
I can't really make sense (see below) of what you're experiencing, but if the supply cable has just a single 'live' cable, then you will not be able to get the timer to run as intended - since to do that you need both a permanent live and a 'switched live' (switched by the light switch.Trying to get the timer working on an Expelair VX100T. There's a single live, a neutral, and earth cable from the socket the previous fan was wired to. Wiring the live to the L on the new fan causes it to run continuously. Wiring the live to the T causes the fan to switch on and off with the light and the timer doesn't work. Any ideas?
Leaving aside the obvious for the moment - where is the neutral, then?
As has been said, it's not the model of fan which is the issue - if it's a timer fan, then it must be possible for it to provide the functionality you want. The issue is the cable, and how many wires there are in it. For a timer fan to work, you need the permanent live, switched live and neutral, and there should also be an earth - hence 4 wires in total (3 + earth). However, it's been known for some people to adopt the 'naughty' (and potentially dangerous) practice of using the 'earth' wire (green/yellow or bare) of a 3-core cable as a 'switched live' - so, if you've only got a 3-core cable, perhaps that is what was done.The previous fan used to switch on and off with the light with a few minutes delay. I appreciate the responses, but from the pic I posted can anyone tell me how to actually wire this so the timer works or is it not possible with this model of fan?
The source you quoted says that it is a switched live in the example drawing they used.Ok, the blue wire is the neutral... but the source I quoted says that it is the switched live.
Hands up anybody who thinks the instructions for the fan show the middle terminal as the earth connection.However, it's been known for some people to adopt the 'naughty' (and potentially dangerous) practice of using the 'earth' wire (green/yellow or bare) of a 3-core cable as a 'switched live' - so, if you've only got a 3-core cable, perhaps that is what was done.
Not only that but, although I have yet to find the full instructions for a VX100T, there are umpteen 'wiring diagrams' out there. All look similar/identical, none seem to show the same terminal arrangement as in the OP's photo, and none show a connection for an earth. I therefore wonder whether (a) the photo the OP has showed us really is of a VX100T and (b) ...Hands up anybody who thinks the instructions for the fan show the middle terminal as the earth connection.
