Hello All,
Late Edit... In case this is your first look at this thread it deals with hot water flowing from cold bathroom taps for in-excess of 30 seconds until they run cold again and is specific to an un-vented cylinder, in this case a 15 year old Megaflo CL210 that was recently partially drained. Never had such a problem with this previously. For the most up-to-date appraisal of the problem please see post #63 on page 5 of this thread. Otherwise, if armed with a large mug of coffee, a plate of biscuits, a comfy chair and an interest in this problem, then please read-on...
Perhaps you can help with some ideas as to whether I have a plumbing or a heating problem. I have a plumbing and drainage contract with one company and a boiler and CH/HW contract with another.
Up until a couple of days ago all was normal with my hot and cold water but when the Hot Water is set to ON I now have very warm water running from the upstairs cold taps for about 30 seconds before they run cold. Leave for an hour and the same happens again. I can get a basin full of water warm enough to wash in from the cold tap. We normally have the HW set to ALL DAY.
Here are some clues as to what may have gone wrong....
We had a brand new mixer tap fitted in the kitchen a few days ago by the plumbing people. Since then the water pressure from the kitchen tap seems higher. I have regulated this a bit by using the in-line isolator valves just before the flexi pipes to the tap. I also notice that when I shut the tap off the pipes rattle a bit sometimes. This also happens every time the downstairs toilet cistern finishes filling and the valve shuts off. Although this has always been the case since we had a new valve fitted a few years ago, it just seems to be a bit worse now.
I contacted the plumber who says he only changed the tap so could not have changed the water pressure. Fair enough.
I notice that NRVs are fitted at the inlets to the mixer tap so probably no problem there.
When he fitted the tap he had to cut down the copper pipes to fit the new flexi pipes which were longer than the old ones. He turned off the cold water mains under the sink and asked me to run the hot taps in the utility room and downstairs toilet to relieve the water pressure whilst he worked.
After the hot water had been running for a few minutes I got concerned and switched the Hot Water to OFF on the timer switch. It seemed to me that the hot water tank would be draining down but not getting replenished with cold water. Anyway, he completed the job and left.
A day or so later we noticed the warm water running from the cold taps.
We have a year old Worcester Bosch Greenstar 24Ri 'Heat Only' boiler in the utility room and a pump in the airing cupboard. I noticed the pump was running even though the boiler was not heating. I know there's a few minutes over-run but on investigation I found that with the HW set to ALL DAY the pump was running continuously whether the boiler was firing or not. When I turn the boiler stat down low the pump just keeps running. The only way I can get the pump to stop is by switching the HW to OFF at the timer. The pump then over-runs for a few minutes longer and stops.
If I switch the CH to ON with the HW to OFF the pump behaves normally. ie if I turn the wall stat up the pump starts and the boiler fires. When I turn the wall stat down the boiler shuts off and the pump over-runs for a few minutes then stops.
So, it seems I have two issues...
First, the pump in the airing cupboard runs all day whether there is a demand for the boiler to heat the hot water or not. I have now changed the timer settings so the HW only comes on for an hour or two a few times a day. I'm fairly certain that previously the pump would stop after the boiler shut off, even if the timer was still set to ON.
Second, I feel that the water pressure is a bit higher since the new mixer tap was fitted although I can't see why this would be.
Having spoken to the plumber who said it's nothing he did, I have now arranged for the heating people to come next week to investigate.
I'm trying to get an idea as to what the most likely thing is to be causing the problem as I have visions of the plumbing people and the boiler people both saying, ''Its not our problem guv''.
Any help or ideas would be appreciated.
Edit.... it may be worth mentioning that it is a sealed system so no tanks in the loft. Also, my feeling that the water pressure is higher maybe just my imagination so could be a bit of a red herring. The plumber draining down the hot water for so long may be more of an issue than my perception of the water pressure.
Many thanks.
Endaxi
Many thanks.
Endaxi
