Hi
Wonder can anyone help.
I have purchased a house which has an old round timer with 2 on and 2 off settings. Beside the timer I have 2 switches one for heating/clock on & off and other for pump. I have also a back boiler in the fire.
I am not sure best way to use this. I have not lit the fire yet but I presume that when I do after while I switch the pump on to heat water or radiators?? Also I have had heating on with pump on and this heats radiators and with pump off this only heats water would this be correct?
I also have been checking my tank in hot press and this only heats half way to the top the bottom half still cold. I have a electric power shower which I think is dual feed (hot and cold) so uses half the tank very quickly, should the heating not be heating the whole tank?
I also have an immersion heater which would has been on for an hour and only gives a little hot water as well.
I can post pics of system if required, any ideas how I can improve this?
