Hi, last year I moved into 1820s house / cottage where security was non existent - ie limited to some window locks only. I was used to a fully operational / wireless alarm system with keypad & siren box etc. This was a dumb system though so for my current house I looked into setting up a smart wireless alarm that could be controlled by a phone app etc. Here's what I came up with :-
I started off using a Hive based system with motion sensors, door sensors etc. I already had the Hive ecosystem to use for my heating so this I thought was the next step. This turned out to be not too bad, I could be notified of movement to my phone etc even when I'm not in. The sensors were very small and discrete (important in an old house) and the batteries lasted for ages. However, Hive do not sell a siren of any type so I cobbled together an internal siren by wiring up a sounder to a 12v power adaptor which then plugged into a Hive Smart plug which of course I could switch on via Hive in the event of movement etc. This worked ok but with Hive there was no external siren there was no concept of arming / disarming the alarm etc - it all had to be scheduled which is not flexible enough.
I found out that you could use the Hive Zigbee based sensors with the Samsung Smarttings hub which also supports Zwave products which includes sirens !!. Smarttings also have a Smart Home Monitor available in the app which you can use to arm / disarm a motion based alarm system. So I migrated all of my Hive sensors to Smartthings (I still use Hive for my heating) and setup a proper triggered alarm system. For this I purchased a Zwave based internal siren as well as an external one with strobe. I use the internal one to not only sound during an alarm but to also to chirp when the alarm is armed / disarmed within the app. We have a lampost on our drive, and this also lights up in the event the alarm is tripped.
So, we now have a fully operational discreet wireless smart alarm system that can be armed / disarmed locally or remotely without any codes via both of our phones etc. All movement for all 5 sensors is logged and we are both notified directly to our phones if this movement has occurred when it is armed (including out outhouses in the garden). This enables us to take action whether we are in or not. The only downside being that we have no battery back up.
Next steps are to add some Zwave smart smoke sensors to the same system. Normal ones are lifesavers if you are in at the time but who's gonna save your house if you are out ?. Again we will be notified directly in the event of smoke being present - including alerting the neighbours using the external siren etc.
Just thought I would put this out there in case it helps / inspires anyone. Feel free to ask questions - cheers.
