its not too difficult, they are all works based, no guarantee of salvation, and they have no relationship with God. religion is mans way of trying to reach, please God.
works based means, you do enough good, you might make it. but scripture says our good works are as dirty rags to God. meaning your good works cannot take away your sin.
You want to believe in fairy tales, or unwritten history, or have had a special visit, or any other reason, you go for it.
But you cannot challenge the logical questioning of somebody asking why, if you believe in religion, why 1 is right and all the others are wrong.
If, and it is a big IF, there is something true about religion, then the only 1 belief that makes any sense is the oldest, original. That is, way before Christ supposedly arrived. Hence the questions about Stonehenge, or any other pre BC event. I am not in a position to say what the earliest
religious happening is, but I am very confident it is not christianity. Which makes it a copy, a different version. Which means it cannot be right, if it was created by word of mouth and not writings, then the story changed too much over the generations for it to be accurate.
Don't knock other religions if you can't prove your version.
Don't try and tell me 1 version is right, any version, unless you can prove it. By prove it, I don't mean quoting things from the bible, that was written generations after any possible event.
You then get on to the scientific history and none of the
stories make sense.
Which all means you are following a story. Carry on if it helps you, but can you not live the same style of life without having to follow
your system? Most people can.
