- Joined
- 28 Dec 2018
- Messages
- 3
- Reaction score
- 0
- Country
Hi, please see attached photos (blue: cold mains to boiler and kitchen after bathroom. Red: hot from boiler to bathroom. Yellow: gas to boiler. The other pipes are the radiator pipes that do run across under the pipes at the radiator ends - again too close to them) is this okay? I’m concerned that the hot and cold pipes are too close to each other and I’m aware it’s not recommended, although they are separated by that mysterious material (to me) above the joists but it doesn’t look satisfactory. It runs like that for 3m and then down to the boiler and kitchen.
This a 2 bed small house with combi boiler and the hot will not be used so often, hence I’m thinking it shouldn’t be that bad.
I’d appreciate your opinion on this. I did consider other options but it will involve using plastic pipe across the joists or the cold pipe running behind the skirt board - I do have some decent gap behind due to plaster boarded wall.
