Hi all,
I'm after a bit of advice and/or reassurance.
I've recently had Hive installed (single channel receiver) via BG (British Gas) and it works very well, however, the concern I have is that the hot water has to be set to 'Continuous' via the switch on the left hand side of the boiler and the inbuilt programmer set to all day for both CH & HW, for hive to work as it should.
My understanding is that the hot water store is maintaining temp and topping up when it needs to (this can be at the middle of the night missus not happy), therefore it must be using more gas?
I'm currently trialling setting the inbuilt timer to match the Hive schedule, which means the the CH & HW will only come if both timers are actively on(Hw set to timed), which obviously defeats the purpose of have Hive. This trial should give an indication of gas usage between the two configurations.
Is there any other configure can I try that will prevent the HW being set to continuous? Should I be using the duel channel receiver?
Cheers
PJ
Cheers
PJ
