Hi All,
Have a question on phone cabe for the internet. I know having joins/extensions results in a drop in speed for the internet but....
My house had 2 lines when i moved in and i've just had one connected. I now want to swap them over so i can move my router. I have the main cable outside my house and a 6 wire coming in to my main socket. I want to crimp the second line in place of the one currently connected which i am ok doing but wanted to know if I crimp both lines to the main pair will that slow down my internet speed? i know it does if an extension but in this case both would be coming off the main pair so not so sure. I am an ex bt engineer but dealt with 4800 pair cables so domestic not my thing
One other question which im not sure the right section for.
I need to run a ethernet cable to a room. I assume that has to plugin to my router and can't be connected to the main phone cable outside?
If I have a cable coming in from outside would i lose any speed terminating the cable to a socket and then having a lead from that to the router rather than having the cable go straight into the router. Reason I ask is the external cat cable isnt that flexible like indoor is.
thanks in advance
thanks in advance
