I thought id start its own thread on this query i have concerning strip foundations of a garage.
If the garage foundation will be a strip foundation 900 wide x 300 thick with 10mm wire mesh or rebar for a double skinned block walls with 100mm cavity, then later a 150mm slap poured with 10mm wired mesh for the floor area. This will be after the block footings have been built to dpc level.
When digging out for the strip foundation, is there any need for digging out under where the roller doors are going. Im assuming there isnt any need for concrete there, but im open for correction!
I have been considering adding another roller door on the side of the garage including the roller door on the gabled wall facing away from the house at my entrance. The garage openings will have a double steel beams or catnics for over the large openings for the doors.
