- Joined
- 22 Jan 2007
- Messages
- 8,526
- Reaction score
- 4,533
- Country
Visit to a new build site today for a couple of boilers tripping electrics (RCD)
New Dual RCD Consumer units, the odd thing is though they trip very intermittently and also they sometimes trip the opposite RCD,
ie on the first property, The heating circuit is on RCD 2, but when turning on fused spur to boiler RCD1 Trips.
On second property it can be alternate, sometimes RCD1 trips, sometimes 2 (with heating load supposed to be on it) and sometimes both. This is with all other MCBs turned off. (also found on pressing test button or RCD1 nothing happens/stays on and powered)
When the wrong RCD for the boiler trips, it does not cut the power to the boiler and it continues to run as normal.
Took a few photos of the consumer units. Remember reading before about neutrals or circuits joined between the 2 causing similar issues. But wanted to get rough idea what's causing it to explain to site agent as it will just be a case of site electrician goes out and blames boiler again.
