Low Resistance on IR Testing
Not what I want to hear, nightmare. Strange how all reels have produced same result, im stuck with what to do now.
Even though everything you have done seems to have confirmed (seemingly 'beyond doubt') that the meter is telling the truth (even with new batteries), if it were me, before I started even thinking about the nightmare situation that you could be facing, I think I would probably want to see that a different meter gave the same results.
May be worth talking to Tlc they may want to do some tests, if they are selling it as Basec approved
I was suggesting it is very unlikely the cable is faulty - does the Meggar show infinity when tested with nothing connected?
The other possibility is nails and screws through cables, but usually they will produce very low Ohms and unlikely whoever managed to hit every circuit anyway.
Hi, yes >999 when i test with nothing. I tested a left over reel and that still fails. I have 11 radials and for them to hit everyone would be unlikely.
He has confirmed that. He also has one circuit (wired in different cable) which IRs as expected (>999 MΩ) with his meter.
Quite apart from the fact that, as you say, these are not the results one would expect, nails and screws through several different cable runs, with the same effect in all cases, would surely be totally beyond belief, wouldn't it?
Edit: sorry, I typed too slowly again!
I purchased over a year ago, so not sure what they would say. but maybe drop them a line.
If that's the case, and if it were a 'batch problem' (no matter how rare that might be), they might already be aware of the problem.
I will give them a shout in the morning and see.
More pressing, what to do now.
Tech its OK and would pass if you go by the guidance....
I agree. If you have two reels affected similarly, it just has to be a bad batch and they would certainly know about it from other customers at the time.
I thought I read about a batch of sub standard cable (imported with fake markings) which got through to the wholesalers some while ago? The suppliers liability will be limited to providing replacement cable though, they will not pay for the time or labour.
I would still want to check it first though, with another instrument, just to be certain.
I think you should.
As I've said, 'unnecessary' though it appears to be, I would personally first check with another meter before I even contemplated 'doing' anything.
That might depend on what (if anything) you learn from TLC. If not only the existence of the problem but also the nature of/reason for the problem is also known, then that may give you some insight into whether the problem is likely to get worse over time - which, in turn, might influence your decisions. I suppose that, assuming the situation persists, and regardless of what you feel 'should' be done, you probably really need to discuss the situation with the customer.
Are there any labels or marks on the drums to give any indication of batch numbers?
In your picture you have one end splayed for your probes but the internal end appears to be just cut straight. I would splay those ends as well, just as a final confirmation that nothing is touching each other.
Will check tonight, i think there is. But I did buy the drums at different times, so would have to be so unlucky to get so many bad batch. I was wondering, they were stored in a garage for over a year, wonder if that caused an issue?
