Hi all, had to remove a radiator and fitted a cap to the end of the pipe. They were the type which contain a ring of solder and just require heating.
On one pipe it worked perfect and you could see the solder out the edges of the cap. On the other pipe I heated it for a long time but no solder appeared. But with the heating on nothing leaked.
So my question is, would you do the cap which didn't show any solder again? Or is this sometimes the case and it should be fine?
