Maybe not as such, but you repeatedly seemed to be suggesting that you thought the first thing to be done should be to contact the DNO. Given the amount of time the DNO might well take to investigate an issue which only manifested itself for seconds once every few days, I still believe that it would be potentially dangerous to do that as the first step and then do nothing else until the DNO had reached some conclusion.I never said I was against speaking to neighbours or calling in a spark.
It's not 'my issue' (which only got mentioned in passing) that is the point.As stated, 2019 has started having frequent blips and this started recently. That's different to your issue where you have blips with gaps of several months between instances.
Opinions clearly vary, and I can only offer my personal view. If I were experiencing the same as the OP, and if none of my neighbours (having questioned a good few, since some would be on different phases) were having similar experiences, then I would not be comfortable to just inform the DNO and wait for them to hopefully do something. As I said previously, I would consider the possibility that the problem could be due to a fault within my installation (e.g. a loose connection) which might represent an ongoing fire hazard if it went un-investigated, and hence not detected or remedied, for an appreciable period of time.
On the other hand, if one or more neighbours were having similar experiences, then I would be reasonably reassured that the problem (whether remedial or not) was outside of my property, and I therefore would probably be happy to wait for the DNO to deliberate.
