With our old fitted wardrobe, I drilled a hole in the corner of the dresser to pass some wires for a TV (power, co-ax and ethernet). I used a spade bit and probably slightly too much pressure so the hole wasn't a clean cut all the way through.
This time around, we have a new fitted wardrobe with a high-gloss finish. I need to run a single power cable through for the extension sockets (non captive so I just remove the plug, feed the wire through and rewire the plug) without causing damage.
What's the best approach to get a clean cut?
