I have just bought a replacement bathroom extractor and also a 3 pole fused fan isolator switch since the old fan wasn't installed with an isolator and the fan manufacturer recommended a fused switch.
I have a question about the wiring between the fuse and the switch. Can I use a section of single insulated wire stripped from a piece of 3 pole cable to connect my fuse out into the (permanent) live of the switch i.e. a bit like the attached image or is there another way to do it? Also, does it matter if the fuse is wired before or after the switch?
