Is that in addition to the 3-pole isolator they also require? Per what I recently wrote/intimated, it could be that they are talking about having a double pole 'fused spur' (FCU) in the feed to the light+switch and then, in addition, a 3-pole isolator feeding the fan - hence both L and S/L would then be protected by the fuse.All the instructions say is a double pole fused spur although further in the detail it says an omnipolar switch. It also says the circuit must be protected by a 3A fuse.
As EFLI has said, there is no other way (that I can think of) in which one could avoid the risk that the S/L would remain live at the fan even though the fuse protecting the permanent live had blown (even having two fuses would not achieve that).
