I am having difficulty finding details for this fan.
Am I right in thinking it is an in-line fan which will be in the loft?
Probably - since that could perhaps be the last nail in the coffin of the (pretty pathetic) argument in favour of having a 'fan isolator'.Yes, so bathroom light is irrelevant.
Well, electrically speaking, there's nothing wrong with it. The '2-pole isolation' will totally kill all supply (including both permanent and switched live) to the fan - but the 'problem' (in some people's minds) is that it will also kill the supply to the light.Didn't spot the obvious difference in the diagrams, I think I just had my head in my hands. I've sent the question regarding the isolator missing from the supplier's diagram (but haven't asked why that diagram wasn't included in the installation instructions in the first place).
Are you planning to instal it so it continues running for a period after the light is turned out?
It is, and I suppose that we have probably all assumed (yes, I know!) that the OP would not have gone to the additional expense of buying the timer model (he has been talking about both permanent and switched L throughout) if he did not want that functionality - but I agree that we need him to confirm that.This is an important question and affects how it needs to be wired.
Indeed so. Thanks for confirming.It was the timed functionality I was looking for. I've assumed the fan will need to run for at least a short time after the bathroom is vacated and light switched off to clear any steam/condensation.
I think that everything the OP has said implies that it was - but, again, I'm sure he can/will confirm.Did your old fan work with a timer function? If so, you can find and resuse its cable,
As has been discussed, it's not quite as simple as just "re-using the old cable" if the OP wants to use the fuse module in his isolator to protect the light (hence also the fan's S/L) as well as the fan (it appears that the old fan had neither a fuse nor an isolator).If not, you will need to find the connections is the ceiling rose for the lamp. Photograph it with the cover open and post here BEFORE you disconnect any of the wires.
