Hello
I'm looking to replace the LED downlights in my kitchen. The current setup doesn't work well - the lights only come on with the second or third flick of the switch and when they do, they start to flicker after a short time. I found out that this is down to the current system using a transformer, rather than an LED driver.
I purchased a driver from Integral LED (50W Constant Voltage LED Driver, 200-240VAC to 12VDC:
https://integral-led.com/products/d...tage-led-driver-200-240vac-12vdc-non-dimmable
Plus six LED downlights from the same company:
https://integral-led.com/products/d...ed-downlight-round-white-insulation-guard-and
I'm going to fit 5w bulbs in each, so that will be 30w total.
Now, rather than faff around in the loft, I thought I'd see how they work by wiring one LED and the driver to an ordinary 3-pin plug. Thing is, the light doesn't come on. I tried two lights in series and still nothing. Current is going into the driver OK and coming out the other side.
Is there a minimum wattage that should be in the circuit for them to light up? If not, any other ideas on what could be wrong?
Cheers
Pete
Cheers
Pete
