I'm a bit new to DIY exterior painting, so I'd appreciate some advice.
I'm repainting a timber exterior door and frame.
1) The door gets slammed a lot, so I want a filler/paint system that will withstand the vibrations as much as possible.
2) I say 'exterior', but it is under an open awning roof, so doesn't get much/any actual rain on it
I have limited time, so I'd like to save effort as much as possible on scraping the old paint off.
so far:
I've had to take the _joints_ (e.g. between door panels) back to bare wood, due to the cracking of the paint and filler.
The _plain faces_ are old gloss on an acrylic primer. The primer is sound and I'd like to avoid removing it, if possible. I've had to chip off _some_ areas of the gloss topcoat as it was very cracked (20% of the total area). The rest of it is less cracked and could probably survive with just keying and repainting.
So my questions are:
-For those areas where I stripped it back to bare wood:
1) With what do I fill the gaps between wood panels?
Woodfiller? Caulk? Woodfiller THEN Caulk on top? (The gaps are typically 2mm wide and 5mm deep). (I'm thinking that a layer of caulk would help absorb the vibrations from door-slamming).
2a) Do I prime the bare wood before filling it? Before I apply caulk?
2b) Generally, what is the correct order for applying Primer-Filler-Caulk-Undercoat.
3) I have a tin of water-based exterior primer-undercoat. Is that OK or do I need an acrylic undercoat?
4) Is standard oil-based gloss topcoat ok?
For those areas where I have chipped-off the gloss topcoap and exposed the old acrylic primer :
5) Do I need to key/scratch the old primer before applying (water based) undercoat to it ?
6) what KIND of filler do I need to bring the thickness up to meet the areas where I kept the existing gloss (0.7mm)?
I imagine that the textbook answer is 'take everything back to bare wood', but would like to avoid doing that if possible
tia
so far:
tia
