How to get power to floodlight?
27 Sep 2011
I would like to purchase one of these for my garden
https://www.screwfix.com/p/lap-weyburn-led-floodlight-10w-white-cool-white/952fx
However, I am a bit confused on how to get power to the floodlight
Can I run a cable 1mm from the light to switch (2 gang). Currently this switch is powering a florescent light in my kitchen?
Or do I have to run a cable from the florescent light to the floodlight. Then another cable from the floodlight to the 2 gang switch?
That depends on how it is wired at the moment.
Turn off the power at the fusebox(consumer unit) and open up the switch and show us some pictures.
Image of current setup
It's a two gang switch which is powering two separate lights in my kitchen
I did some of the wiring, so please don't slate it :D:D
Has the red/black cable got an earth wire in its sheath? The blue/brown cable has an earth but it does seem to be connected. It should go to the back box. I assume you did the blue/brown as that is the latest. Is the earth at the other end of the blue/brown cable connected?
As to your question, it would appear there is no neutral at these switches so you would have to do the 2nd of your options and change the switch to a 3 gang.
Cheer Winnie
The red and black cable has earth however throughout the property this appears to have been deliberately snipped by the installer
All of the light fittings and switches are plastic
However some parts of the florescent light is metal and the back boxes are metal too. Do you recommend extending the earth by soldiering and terminating in the backbox?
Also i have no back box at the moment as i removed this to do a bigger chase for back box/conduit.
The earth in the blue/brown which i did will be connected to the backbox. The other end is connected to a connector strip (to. Extend wire) but the earth to. The florecent light is not connected
Thanks for the help
I should also point out that the property does have some wiring to an old outside light (which i want to replace)
I have uploaded an image of the wires that were feeding the original flood light. There was a swich here.
I am not familiar with the cabling but would it be possible to use this wiring and connect it to the 3 gang switch (which is on yhe other side of the room?)
There appears to be a puple, brown, black and earth cable
Cheer Winnie
This needs to be rectified throughout the property especially if there are metal light fittings like your florescent.
Cheer Winnie
Yes.
i suggest you get an electrician to come and sort out your wiring.
Andy
The electrician's already been out and he aaid that my wiring is good.. he said that as long as I use plastic fittings then I am good.
I wullbe changing the florecemtf lights for some downlights that do not require earth
Anyone have any comment on this wiring?
Can I use this wiring for my outside flood light?
The outside light you linked to in the first post is not plastic!
Here we go again...adding to a lighting circuit now requires an RCD no cpc...needs sorting........come at me
True (certainly for the 'added' bit), but who has told us that the circuit is not RCD-protected?
In my experiance and looking at the existing wireing i would say that there is a 99 percent chance of no rcs
Experience of what? You obviously can't be suggesting that there is a 99% chance of there being no RCD in any domestic electrical installation.
You may, of course, be right - but no matter what probability you care to mention, you are simply guessing.
