- Joined
- 27 Jan 2008
- Messages
- 23,700
- Reaction score
- 2,670
- Location
- Country
Bernard has not claimed it was his shower having a problem.In recent weeks there have been several pleas for help from people who could not have a satisfactory shower because the water would go cold while they were showering.
How does this have any bearing on the problem when Bernard has not claimed the problem is his.remember typing this
I have a shower with full mains water pressure.
The green / orange "box" in the top of the cylinder is a "coil" with a large surface area.
Read more: https://www.diynot.com/diy/threads/replacing-my-thermal-store-and-boiler…help-in-specifying.455158/page-4#ixzz5vNThOXfA
bernard,at certain times your bespoke sidewinder could be allowing warmed water back into the cold water main. seen it a few times
I had a Main 7 gas water heated fitted in last house, and in the main it worked OK, however some shower heads did cause a problem in the summer due to not enough water going through the head. I drilled out some of the holes in the head, cured.
My mother had a Worcester Bosch Greenstar 28i this also had a problem, however it was not the same, it was caused because it heated up a small store inside the boiler to reduce the time between turning on tap and getting hot water, selecting eco mode switched this off, so shower worked better, but it also resulted in if you turned hot tap on just a small amount to for example rinse dishes, the boiler would not fire up. So answer was Eco off but run shower longer, it would go hot, cold, and hot again and stay hot.
Even the washing machine seems to have a problem tumble drying cloths when in coming water too hot, it uses cold water to condense water.
So from my very limited experience yes hot water feed can be a problem.
This to my mind is a far bigger problem than if the shower works, my cold water is never anywhere near 20°C and even the water in the water tower after being in the sun all day is not that hot, while painting it, I was unfortunate enough to get wet with the water while filling a real boiler water tank, one that actually boils water. OK not a big water tower, but seems odd water allowed to get that warm?HSA said:Legionella bacteria grow best between temperatures of 20°C – 45°C with optimum growth temperature being 35°C – 40°C. High temperatures (minimum 60°C) kill the bacteria. Legionella bacteria are found in low numbers in natural aquatic environments, for instance, lakes, rivers and ground water.
The shower is the big problem with legionella as the water is atomised so breathed in, the one case I know about at work, was the guy washing down trucks using the hot water designed to make concrete where water temperature is critical for correct curing time. It was because water was atomised so he was breathing in the fine spray.
