- Joined
- 10 Aug 2019
- Messages
- 4
- Reaction score
- 0
- Country
I've been recently informed by my immediate neighbour that he thinks our soakaway is damaged (or incorrectly constructed) and I'm trying to see how I can confirm this. If I can confirm there is an issue, and I can locate the soakaway I'll happily get it repaired or replaced.
The background is that we live in a 15 year old house on a steep hill and the two houses share a boundary. About six months ago the neighbour removed some soft landscaping and extended his drive with block paving.
The area can be seen in the following image. Our house is on the right. Previously soil height went up to the bottom of our cribbing (as indicated by the pale patch on the concrete footing) and sloped towards the tarmac on the left. It was covered in established shrubs, bushes and three small trees.
Now that area has been changed from soft landscaping to hard landscaping it has been noticed that in heavy downpours a volume of water appears to flow from the gravel at the top of the block paving, washing the sand that has been used to bed it in down the road.
To date the water is flowing from the gravel in two places; from above the BT box and approximatey 1.5 metres towards the houses. Each area of flow is between 50cm and 1m wide. It does not appear to be flowing over the concrete footing or the soil onto the gravel.
I do have a video, but unfortunately I'm struggling to upload it.
This flow of water is understandably causing the neighbour concern, and he's asked me to get it rectified as soon as possible. He can then reinstate the sand and repair any damage to the sand bedding under the blocks.
I've spoken to one of the builders involved with the site 15 years ago and he tells me that from his recollection we have "open tank soakaways" and that he is not aware of issue reason they would start to fail.
Therefore, my questions to the DIYnot.com collective wisedom are how can I go about confirming that the soakaway is at fault, and how can I confirm its location?
I've lifted the closest rainwater inspection cover and found no water backing up. I've also put a hose down the closest downpipe to the area in order to see if I can get water to appear in the same location and so far I'm failing miserably. It stays dry.
Any advice would be greatly received. I've been searching the web in order to find a competent professional that may be able to help, but at present I've drawn a blank.
Kind Regards,
Nige.
Kind Regards,
Nige.
