Put very simply, my interpretation/view is that any conductor(s) which carries the full load current (fully 'end-load' current) is/are part of the "power circuit" (not a "control circuit"), even if items within the current path can switch the current on/off (or even change its magnitude). On the other hand, anything (components and conductors) which 'controls' the load current (on/off or variable), without carrying the full load current, is part of a "control circuit".
I really wish it was that simple. I am happy to say that in essence I agree with this definition but unfortunately that distinction is frequently not there. A simple example would be to place a relay or contactor coil (Sorry for the autocorrect 'contractor' earlier) across the load in a power circuit (a not uncommon scenario) and that device then controls something else. Suddenly a power circuit by your description has been changed to a control circuit.
In real life the control panel and all the associated peripherals are classed as control.
Another example and this time a simple one, a heating company were called in to look at a heating problem and found a pump had failed.
They removed the pump and returned the following day with a replacement, fitted it and left it running.
That day the heating stopped again and a different engineer found the overload had tripped, reset it and turned the adjustment up to maximum.
Several days later the pump failed, it was replaced and returned to supplier under warranty.
Several days later the pump failed, and it tripped the overload. Overload reset and pump replaced but it kept tripping and diagnosed as faulty overload.
Electrician attended to replace overload (wrong make so it was a real botch to make it fit) it was again set to maximum (something twice the rated current) as it kept tripping.
Sunray was asked to have a look by a Controls company and was greeted with 'another person, do you reckon you can do any better than the other 6 visits?'
First job, take lots of pictures, lots of voltage and current measurements.
Any ideas?
It is an electrical issue, not plumbing.
