and your only wanted 1 foot or 2 from what I recall !
That was rather different - nothing to do with core colours but, rather, the fact that I was looking (not very successfully) for 1 or two metres of 6-core flex, but eventually realised/discovered that 7-core (although not 6) is pretty readily available.and your only wanted 1 foot or 2 from what I recall !
well, no matter what the colours were, in the absence of any 'regulations', I don't think there would ever be consistency!Seen it in white a lot, mainly for single phase and a permanent Live, confusion comes as its not always consistent what is used as permanent live, some use black and some brown.
Interesting. I have to say that is the opposite of what I would almost certainly do myself - since, in 3-core (single-phase) cables, brown id the ('permanent') L, I would almost certainly stick with that when I used 4-core, using the 'other colour' (black or whatever) as the S/L.Hagar tend to use Black as Permanent live in there prewired plugs, and that seems to be the most common way.
You used to be able to get anything from 4 to 7 core flex with the additional cores all black. They needed numbering or sleeving to ID them.
IIRC grey cores were introduced when the UK moved to harmonised colors for fixed-wiring cables in the early 2000s because the UK objected to having multiple black cores in standard 3-phase cables.I think all harmonised-colours 4-core flexes I've seen (and used), plus things like SWA, have had brown, black, grey and G/Y cores. My point was that I don't recall ever having seen brown, blue, black and G/Y before - have you?
No, of course not - I use 4-core flex 'all the time'
Our experiences clearly differ. I've used a fair bit of 4-core fles, and have a fair bit 'on my shelves' but, as must be apparent from the fact that I started this thread, I've never seen those colours used before.4 core flex is almost always green/yellow, blue, brown and black.
Are sure about that?aptsys is talking about the "old colours" ... and you are looking at "new colours" available now.
The colour code for flex was harmonised decades before non-flexible cables.Are sure about that?
For a start, what part of "... IS almost always..." refers to decades ago? ... and, even if it did, would "blue, brown and black" really have been acceptable under the 'old colours' (when black was neutral and brown had {as far as I am aware} no defined meaning for LV AC wiring)?
