Hi
I had what could be described as a lean to on the back of the house. Was part of the original house. The water off the house roof was fed onto this little roof which then was fed Into what I assume is surface water drain to the left hand side.
I have now had an extension built onto this lean to. So the lean to roof has come off and replaced with a normal pitched roof (so runs the other way if that makes sense). So the water off the left hand side of the roof goes into the original drain. The water off the right hand side has been fed with a drain pipe so it enters the foul drain under the kitchen window.
Is this even allowed or is it going to cause me a problem when the building control guy comes to approve the completion. (99% completed now)
Cheers
Cheers
