Brown, Blue, Black and G/Y flex?
Flex of course in commonly used on central heating systems, in fact many use it for the entire length of the roomstat and all that, to save joining from flat to flex when entering boilers etc.
Traditionally, every piece of central heating would require a neutral.
I'll double check what colour is in my current roll of 4 core flex.
Flex of course in commonly used on central heating systems ...
Indeed, and that is just one example of those situations I mentioned in which one wants N, L and S/L (plus CPC) - for which 'three L colours' (brown/black/grey) is, in my opinion, not ideal.
Let's face it, certainly if it's fixed wiring, if we want to be regs-compliant, we'd have to 'create a blue for ourselves' (by over-sleeving).
As I say I'd be interested if anyone has a good source for brown/black/blue/green & yellow butyl flex for dual element immersion heaters. As most of these that I am dealing with are across the border remarking a conductor blue for neutral is a rule breach and a prohibited practice.
It used to be easy to get here but newer stock in the wholesalers all appears to be in phase colours now (apart from some non-heat resistant flex available in those colours).
I'd rather not have to travel to Dublin to get it if possible.
As I illustrated, the first one in your list only seem to offer brown/black/grey +G/Y. I don't use any of your others.
I didn't read the description but I thought the picture looks like it's blue and I have certainly purchased with blue from TLC.
No I don't use the others either, I simply googled for 4 core flex and looked at the pics.
Easy, use 5 core.
This offcut of SY came 'off the shelf without preordering from CEF in 2017 for connexions between VSD's and Fans.
Another one for Ristard.
I've just had to replace a damaged plug on an extension lead.
This happens to be the last 25m or so of a drum of 2.5mm² butyl that I purchased from Newies in July 2018.
Ironically most of the original use was 3ph and I had to over sleeve with brown.
Even more ironic, grey silicon sleeves are easier to source than brown...
PATing and putting cables away for the winter.
This 4G1.5 rubber was purchased during the summer for loudspeakers, knowing where the job was my colleague would have got it from one of: Newies, city, RB Star, TLC or Edwardes. Some was used for this extention lead.
6mm² Brown twin with a ribbed polarity ident.
Grey/Blue 10mm² twin easy to source but Brown/Blue or Brown/Grey are not so easy.
