Are cavity trays above door and window openings compulsory to meet building regs or can you still use Stepped CPC over a minimum 150mm step between the inner and outer cavity walls with weep vents?
I've never used cavity trays but heard some bad things about them years ago when i done an extension. Getting blocked or leaking maybe.
Having a quick look i can't see how they work as it just shows an angled length of plastic set into the outer bed of mortar and angled up to the inner wall but not into the inner wall.
