Hi
I am attempting a self install with Hive with an Ideal Combi
I will isolate all electrics and want to make sure that I am doing things correctly before I do the diy work at home at get stuck.
Is my wiring diagram correct below?
Can I use the mains into the boiler and connect off the same connector with a new wire to the hive unit for the permanent live?
Is my 3093Y 0.75mm2 cable selection appropriate? And what cable should I be using for the red lines (live & switched live to the HIVE 2)
Any advice is much appreciated!
Cheers
Cheers
