Ideal standard lx boiler keeps firing
17 Nov 2005
Manchester
my boiler is a little old but I am waiting until it completely gives up to replace it. At the moment it keeps firing up time after time hot water and rads seem fine, it does settle after a while. What could the issue be please?
I have already replace the fan in the past for a different issue.
Also whilst I have your attention when it does come to replace old boilie how much would a new economical boiler save me each month please? Currently paying £106 for gas and leki per month, 3 bed detached.
Thanks.
I don’t know about the savings on a new boiler. Your current boiler, does it have a preheat function? If so it might just be that.
have a look to see if you have zone valves, if you do you might have a sticking micro switch in one of them
not a clue what zone valve are sorry.
This morning I have whacked the thermostat on 30 and the boiler is firing up for 20 seconds then cuts out then fires up again, the temp is creeping up slowly but after a couple of hours still isn’t up to temp.
Hi, pictures of my water tank attached
The little box at the bottom is wobbly and seems to be connected to the green tank just by a copper wire, is this a thermostat?
I'm not sure what your problem actually is. Older boilers have a thermostat that simply switch the burner 'on' and 'off' to maintain the temperature of the water leaving it at the level set on the boiler thermostat.
So, for example, if you have a Ideal LX FF 250, it's maximum heat output is '15kW'. When the heating comes on from cold, it will probably run continually for most for the time. Eventually the water returning to the boiler will start to warm up and even get hot, so less heat will be required to return it to the set temperature and the burner will cycle 'on' and 'off'. If the demand for heat drops to 7.5kW then the burner will be 'on' for 50% of the time and 'off' for 50% of the time.
As time progresses and the heating system warms up, the burner 'on' time will get shorter and the 'off' time longer. If this is what you are referring to by:
....then that is what I would expect. If it kept firing continually the water would actually boil.
If I look through the sight glass the burner is on and fully lit but then it will go off fully then fire back up almost immediately.
I have uploaded a picture of my pumps also.
Also, is my hot water tank sufficiently insulated? (Apart from all the old curtains...) should it not have a jacket on?
The green foam cover is the insulation, if you look where the pipes enter you will see that it's quite thick. If it didn't have any insulation on, the cylinder would be as hot to the touch as the hot water coming out of your taps.
40 years ago the hot water cylinders didn't come with insulation so then a separate jacket was fitted.
Thanks Stem, so no further insulation required?
I have been running the thermostat all day at 30 but it is still not up to 30, what could be the problem please?
What thermostat are you talking about? If it's a room thermostat that's very high I wouldn't expect you home to get up to 30 degrees :eek: 19 to 21 degrees would be more usual. The speedometer in my VW golf goes up to 160 MPH, but I doubt it would ever reach it.
If it's the hot water cylinder thermostat that's very low, 60 degrees or above would be more usual.
