- Joined
- 15 Nov 2018
- Messages
- 204
- Reaction score
- 13
- Country
There could well be a purpose built relief hole higher up in the closure plate. Depends on manufacturer.
no, they won't show this kind of thing in marketing pictures, in the same way that boilers and bathrooms are often shown without any pipework!
You'd need to read the installation instructions for a definitive answer on whether your installation is correct.
Its capped off...Take it off the wallWhere would the closure plate circulation vent be located on a conventional radiant wall mounted gas fire.
Images online and in brochures, the vent isn’t visible at all.
However, the Gas Fire fitted at my Father’s House has a huge unsightly hole in the wall under the Fire, which looks terrible?
So installer fitted it and left gas capped off?Presumably it is a second hand fire too? Never a good ideawas Landlords decision to replace the fire due to fault and installer fitted the new fire higher; because the faulty fire, the closure plate and tape protruded above it and looked untidy, although covered by wall paper.
RW visa Firegem relief opening is at the bottom. Suppose alternative could be higher upThere could well be a purpose built relief hole higher up in the closure plate. Depends on manufacturer.
