Fitting a shower in a bathroom.
Shower is a Mira unit that uses Z connectors like this:
And I was planning on fitting one of these to the (stud) wall behind it
The problem is that the shower says the end of the Z connector must be 40-43mm proud of the finished wall - once you've factored in the thickness of the tile (10mm), adhesive (1mm), tanking (1mm) & tile board (12mm) you don't have enough left exposed.
The shower has a rigid riser which is why I guess the spec is so tight.
The best idea I've got so far is to ditch the Z connector for a 1/2" extension of the required length (measured once the room is fitted out), but these seem difficult to get hold of.
Is there anything obvious I'm missing?
