Karcher k4 high pressure hose connection woes
14 Mar 2006
Essex coast
In-laws dropped off his pressure washer which keeps blowing the high pressure lance connection where it leaves the main body .
Held by a C clip which does not hold in use , tried new clips but same problem .? Only had 5-6 uses so unlikely to be worn .
Either the hose isn’t fully pushed into its socket (easily done, needs a firm click) or the plastic bracket that helps to hold the clip has a piece broken off, I imagine.
Never did like these quick release fittings!
John :)
No quick release system involved, lance hose pushes in easily,[brass] no click involved as C clip slides in to lock joint[Initial connection seems very secure, cannot pull out by hand].Bracket undamaged, holds briefly but turning lance off and on is enough to break connection.
The type Ive come across are using an ‘R’ clip (or more accurately a double R) so for the hose to disconnect the water pressure must be forcing the legs of the R clip apart.....almost impossible if the holding bracket is unbroken.
So - if memory serves- the R clip pushes through two holes, slides through the groove on the hose, and then locates in another two holes behind?
Something worn or cracked there, I’d guess.
John :)
Need a pic of that one.....can’t say I’m familiar with that design. Thought it was a brass stem with an O ring that pushed into the hose reel drum somewhere.
Mind you there are hundreds of Karchers, and no two are alike.
John :)
John :)
No hose reel , pushes into the high pressure outlet .
Yep, that’s really a double R clip - of a fashion!
If its disconnecting, either the open end is springing open too much or the slide is allowing the clip to spread - much the same really.
Any realistic chance of tying the open legs tighter with some thin, tough wire or whatever?
John :)
Think it’s sorted , run water thru machine with power and Lance off, ad Lance and run more water then turn on power and all good , air locked.
That is the correct technique when dealing with the cheaper models - allow water to bleed through before switching on. I guess that prevents a high pressure air shock otherwise.
Clearly not the best design!
John :)
Well clip failed again, metal is too feeble so wrapped a length of copper wire I stripped off cable around the open end of the clip and held so far.Awfull design and from searches I made has been a problem for over 10 years .
I do recall having seen this one before, but it was a very cheap machine (£45 I think) so I didn't go any further with it and returned it to its owner.
Your method should be just fine, and its best to leave the lance hose connected anyway.
John :)
Have pestered Karcher and they have agreed to collect and repair foc, will be interesting to see what they do.
Hi I have the Same problem with my K5 tTy this it seem to have worked for me firstly I put the C clip in the vice and squeezed it to make a tighter fit then I put a cable tie on the end to keep the pressure on the clip I put the clip on from the back for better access
How did it go then? I’ve had both of my pressure washers repaired by Karcher and they do give a good service.
