Texecom Part set but allowing entry exit
What attributes are selected on the door ?.....is it going off when you re enter or is it going into arm fail ? Also do you have a dectector near the front door and what is it set as ( zone type )
Figured out the problem, the timer to get out of the entry exit door is too short by the time the part 2 arms, so how do I lengthen the exit time for part 2 ( and turn exit tone ON) but keep it instant for part 1?
Unfortunately you can’t have separate timers for the part sets ...something that I think needs changing in the firmware
In area options I changed the part arm instant from A*** to ****, I was able to leave the front door and shut it, it set the alarm fine, however when coming back in the door the alarm set off, I'd like the front door to still be alarmed when only omitting the PIR I want but still allow me to enter through that door.
Ah, going back to your Guard thing, I removed the Guard attribute and the entry exit works as it should. Great!
But will it effect any other arming modes? Or does the alarm choose it as Guard attribute as standard when any entry/exit type is chosen for that zone?
