We are in the process of tiling our kitchen. The kitchen is half floor boards which have been overboarded with 6mm cement boards
The tiles are 120x20 rectified plank tiles
The other half is a concrete floor
Total area 3.35m width by 6.87m length
Electric underfloor heating is also being installed throughout.
We've noticed the tiler in some areas of the floor primarily on the concrete side has used up to 30mm of tile adhesive!
We questioned this and were advised it is due to the floor not being level hence why less adhesive has been used on the cement board section but more adhesive is required to bring it level on the concrete side
Is this acceptable? If not what would be the correct method to address an uneven floor?
Our concern is that given 30mm adhesive has been used will the underfloor heating still heat the floor?
