- Joined
- 17 Apr 2007
- Messages
- 2,707
- Reaction score
- 145
- Country
Comparable in what way?
Quality of manufacture.
If the supplied trap is anything like the one I had provided, bin it mine blocked in 3 months. The macalpine one I replaced it with has had no issues for The last six .lucky Im a bit slow and hadn't replaced the ceiling below![]()
If you sit the tray edge on and look down it you will see there are a load of points on the tray that are level, use a spirit level and you will see what I mean.
Use 18mm WBP plywood. If you are placing it onto wooden floor boards/subfloor then I'd recommend you lift the boards and insert dwangs into the gaps between the joists where the tray will sit to ensure the boards wont flex ergo the tray.
In that case I'd have the top of the platform sitting slightly in off the edge of the tray
